Parennin x 171
Gaus
Good afternoon fellow forummembers,
I have serviced a Parennin x171 movement. I have replaced the mainpspring. The watch runs nice, but it looses time between 11:00 en 12:00 hours. What can be wrong? I appreciate your suggestions. With kind regards, Hans
Does this happen once or twice a day ?
If once a day then it's probably something to do with the date changing mech not quite running smoothly and the 'drag' causing an issue.
If twice a day then put the crown in the time-change position and take a close look at the hour hand as your move it slowly around the dial ... does it sweep cleanly with an equal distance between it and the dial at all times? You just want to ensure that the dial is seated correctly and the hour hand was put back on level. If this checks out then be certain there isn't some some contaminate somewhere e.g. some fluff or dirt in between a tooth on the hour wheel.
I'm not familiar with the Parennin specifically, and it's difficult to find much info on the web about this movement, so I'll need to talk generally...
A date change mech will normally consist of i) a wheel (or relevant mech) that pushes the date ring forward at midnight and ii) a date jumper that ensures that the date ring clicks forward neatly one day.
The date jumper is just a simple lever with a smooth curved end held lightly in position with a spring. When the date ring is pushed forward it slides over the next notch in the date ring and relocates. However if the original date jumper spring has been replaced with something that is too strong this can cause too much drag (or even prevent a date change) and affects the movement. This is the most likely initial cause and my suggestion to prove it would therefore be to remove the date jumper and spring and see if the date moves forward and the watch continues to keep time.
If however the watch still misbehaves at date-change time then we're to the mech that changes the date. You may need to post a picture or two to see if myself or someone else can spot the issue in that case.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
