Weird beat rate...
mwilkes
Evening fellow clockies
I’ve just spent a long time counting wheel teeth over and over again...
centre 84
third 78 & 7 leaves on the pinion
escape 33 & 7 leaves
...which gives me, I think, 8825.14ish beats per hour!
Does that mean someone’s changed a wheel/pinion in the past? Or did they not really care that there’s no integer beat rate (it’s late 19thC fusee clock from Co. Cork)
First, I'm not heavy into clock, I've done a few but never thought about the beat rate from the mechanism side.
My logic goes from the other end of the stick.
In my world it's the length of the pendulum which determines the number of beats. The longer the pendulum, the slower the beat, the shorter the pendulum, the higher the beat. The pendulum steers the anchor escapement and therefor the speed with which the power is released and the mechanism tuns. The hands for the time-indication are connected to the mechanism.
Change the length of the pendulum and the clock will beat faster or slower. That's how you regulate the time keeping.
So, which end of the stick is it ? :huh:
BTW, looks like a nice fusee mechanism and with (original?) chain ! I wouldn't mind a picture of the (pub?) clock  :)
Edited by Endeavor
Yup I’ll post a pic when it’s back together (the case is being de-wormed, poor thing) - not a beautiful clock.
The thing is, regardless of your pendulum length you can’t get a regular number of beats per hour (though you’re making me doubt myself). In reality the .14 is irrelevant - it’s just curiosity.
The company that makes TimeTrax timing machines has a clock train tables publication.  So going through the book casually I'm guessing That maybe 50% do not have an even count. Not only do they not have even counts for the most part they're all totally different numbers. Which as already pointed out is totally irrelevant as long as the pendulum matches the gear train and the hands revolve the proper rate it doesn't matter.
It is the play between gravity and the length of the pendulum which determines the rate. As written, the longer the pendulum, the slower the rate, the shorter the faster. Funny enough, the weight of the bob, in theoretical therms and under ideal conditions, is irrelevant; not in reality though ...
Gravity here on earth is not everywhere the same either, never mind dragging the clock into space :biggrin:
The length of the pendulum can be changed to any desired length and therefor to any desired rate.
Remember, it is not the clock which runs on time and the rest has to follow. It's a mechanism which does its thing regardless "the time" and it is up to the clock-maker to make the mechanism to run such that it follows / indicates the time. He can change the gears such that the clock follows the time, but it's the length of the pendulum and the amount of gravity which are dictating the rate.
The length of the pendulum (and therefore the rate) can change due to outside influences, but that's another topic and than we are talking about complete different clocks (think of Vienna clocks )
Same as with mechanical watches, it's the rate / frequency of the balance-wheel which dictates the rest.
Edited by Endeavor
    • Thanks for the help guys! VWatchie I already found your thread but I'll check it again. Nice to know about acetone, I still have to get the shellac off since I made a little mess. I adjusted the jewel, put new shellac (the so called soldering technique, pallet tool too hot this time so the shellac "wire" melted in air before getting in contact with jewels or fork) rinsed the pallet fork and put it back dry. Amplitude is now in the 240-250 range that I expected in the first place. I guess there's enough oil in the escape wheel teeth already but I'll check that later. The mainspring was pretty beaten so a new one would probably boost the amplitude even further. Nice to learn new things. Now I have another thing to look for while disassembling. I wonder if the watch left the factory that way.
    • Would be interesting to see it 🙂
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
