making my own movement holder
AP1875
Due to chronograph movement holders costing a small fortune, i am going to make my own.
A family member is taking all the measurements i need and creating an image in Solidworks. We will then print the image or get a metal version milled.
Does anybody know where i can get a the part circled in the picture? Save a bit of hassle making one.
Very interested in how you get on. That part could likely be replaced with a thumbscrew maybe ? To make it more realistic print a cap over it .
One of my projects on my printer was to do similar but NB haven't got enough time as I would like to to play around with this.
Please let us know how you get on.
I did think of a thumb screw, but thought it might look a bit 'naff'. I might end up buying another movement holder and removing the knob. It would be good if i could buy something similar though
sorry i missed the part where you mentioned the cap, could be an option thanks
I would think getting a custom milled job from a local shop would be at least as expensive as buying the holder in the first place. A 3D printed holder would be plenty sturdy (I've printed a few and never has an issue, except where to keep them so I remember which movement they were for. ;) ) You could even 3D print the knob. It doesn't need to apply much pressure to hold the movement.
  • 4 weeks later...
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
