making my own movement holder
AP1875
Due to chronograph movement holders costing a small fortune, i am going to make my own.
A family member is taking all the measurements i need and creating an image in Solidworks. We will then print the image or get a metal version milled.
Does anybody know where i can get a the part circled in the picture? Save a bit of hassle making one.
Very interested in how you get on. That part could likely be replaced with a thumbscrew maybe ? To make it more realistic print a cap over it .
One of my projects on my printer was to do similar but NB haven't got enough time as I would like to to play around with this.
Please let us know how you get on.
I did think of a thumb screw, but thought it might look a bit 'naff'. I might end up buying another movement holder and removing the knob. It would be good if i could buy something similar though
sorry i missed the part where you mentioned the cap, could be an option thanks
I would think getting a custom milled job from a local shop would be at least as expensive as buying the holder in the first place. A 3D printed holder would be plenty sturdy (I've printed a few and never has an issue, except where to keep them so I remember which movement they were for. ;) ) You could even 3D print the knob. It doesn't need to apply much pressure to hold the movement.
  • 4 weeks later...
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
