Had to Remove a Screw
Had the head of screw strip off the mainspring barrel arbour. Tried to use a bergeon screw extractor and failed. So I set the arbour up in a lathe and graved a small cone center. Then I used circuit board drills and progressively drilled out the center. And after two broken bits, I finally got the insides loose. Then I went on my Stereo Microscope and picked out loose parts using rodico and a small pink screwdriver.
All worked well. Now to find a new screw. The main mission was to replace a broken mainspring.9949bbdd78c12cf7e9bbc3ca02ecab3c.jpga86a3b5fc103b4c6e892ef02d8e42e27.jpg3fe416e813d80bd527358fbcb772bb61.jpgbc221c0b9726d814c82a9cfc9aae8a10.jpg
  • Like 6
