Pendent tube fitting!
bosstaki
Hi guy’s! As anybody used glue to fit these tubes back into there watch cases! I’ve got a screw down tube that should be friction fit, its loose in the body & keeps popping back out when i pull the crown out to alter the time!
There is a way to mark the inside of a hole to help it grip by inserting a cutting broach without rotating to introduce some raised burrs.
You can also possibly spread the pendant tube on the case side if you are careful.
Are you sure it is the correct tube. When I have fitted they are just friction fitted. If just a snug but not a tight fit using loctite will work.
Thanks for the reply mate! Which Loctite glue would you recommend i use mate! Cheers!
You only need a medium strength such as the 270, or 290. But any of their range should work fine providing everything is grease free.
Hi clockboy! I got some locktite 680 & its worked like a treat mate! Cheers!
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
