Seiko 6139-6010 aka "Bruce Lee"
Hello guys. This is my last project – Seiko 6139-6010 aka Bruce Lee. Watch is from ‘69and it is based on the 6139A movement. Nice shot for the 50th Seiko anniversary of first automatic chronograph development. So please see the pictures below from all restoration proces. It took me 3-4 evenings.
The watch came to me as non runner. Crystal was scratchy with many chips. Dial was dirty and dusty with signs of water damages. Hands lost their lume. Day calendar was loosen and didn’t work properly. Movement was complete but very dirty and dry – there weren’t any residues of old oil in the jewels. Somewhere were signs of water flood. I dissasembled movement and I gave it a bath in ultrasonic cleaner then i’ve assembled and oiled movement. Star disk od date wheel was repaird with small amouth of resin glue. Movement had tend to stop sometimes. Inspection showed that the tiny chip on the bottom pivot of the escape wheel. It was hard to see it. After replacment movement ran as a champ. I polished the hands cause there was rust and gave them new lume. Dial was cleaned. I didn’t touch the lume on the hours indexes. I was affraid to screw up it. I think now it is quite good despite the fact that the lume does not glow. Orginal crystal was polished but I decide that in the future I will replace it. Case and caseback got some polish works only with polishing paste, not too much cause I didn’t want to loose the sharpnes of orginal edges – as usual I did it. Bracelet was matted with abrasive wool. Everything was mix up and combined and there is the result.
After measurments on timegrapher and adjustment it is a nice timekeeper. An amplitude satisfy me as well. Now I am enjoy to wear it.
Please let me know what do you think of this restoration project and about my works on it. I appreciate your comment and your spend time. Cheers folks
Edited by jackie01
  • Like 7
  • Thanks 2
Wide range of restorative attempts and I say good job, too many to master all though.
I buy more selectively focusing on the work you enjoy tirelessly.
Cute balance cock stand tell about the artistic person in you.
All the best.
  • 4 months later...
Hello, I ha e this watch, which needs a service and maybe a mainspring.
Can you repair/service it for me please..?
It has been cleaned inside by my friend.
We thinking that the mainspring needs replacing.
Please help...
Regards
Zak
Hi, this is only a discussion forum. Members are not allowed to offers goods or services for sales.
You will have to locate a reputable repairer local to you. You can also check a Seiko forum like SCWF for recommendations.
Edited by jdm
5 minutes ago, Klassiker said:
Or, using this excellent forum to help you, learn how to DIY. Much more satisfying.
The OP's friend had a go to the piece already, and if I guess correctly it now suffers of low amplitude, a typical Seiko issue, not easy to correct and for which a new mainspring is just a part of the cure.
I think that for a beginner to attack a desirable chronograph of EUR 400 starting value would a big mistake with slim chances of  success. Much better to give it to a professional, pay a fair price, and enjoy the watch in its best conditions and in conditions to be passed down or resold.
  • 2 months later...
  • Similar Content
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
