Timex 24 setting lever
Haboy
Setting lever screw broke on my Timex 24 movement. I have another working 24 but in need to install the setting lever and new screw which seems somewhat impossible. Is there an easy way to get the lever and screw inserted into the hole?
Hold the setting leaver exactly in place with rodic (or similar), position the screw with tweezers, and screw in place.
... or..
Position the lever with rodico, position the screw with rodico, screw in place.
It is fiddly. I presume you removed any remaining parts of the broken screw.
One other thing that occurs to me.
Fit the setting lever (443) and the screw (5443) *BEFORE* you fit the stem and crown.
Once you have it fitted, screw the screw right down, then back off by about 2 1/2 turns, then fit the stem under the tab that operates the lever and position it correctly. With the crown/stem in position, screw the screw back down till finger tight, and prove the lever/crown/stem is operating correctly, then tighten the screw completely.
Attempting to fit the setting lever, crown/stem and screw all at the same time is a much more difficult (and unnecessary) task.
Edited by AndyHull
most times the broken screw will be accessbile from the dial side of the movement.  I use a pair of fine tipped diaginal cutters to grasp the screw and slowly turn it out of the hole.
TIP -  Apply some watch grease to the bottom of the set lever to hold it in place.   Line up the holes and with tweezers, drop the set screw into place.  The turn the screw about 2.5 turns.
Thank you AndyHull and JerseyMo for responding with really helpful instructions!  You guys rock!  i have to get some rodic to help hold these two little mini-monsters in place. I was trying to use a small bit of sticky-tack but it didn't hold well enough.  I would get the screw into position but it would fall over when the screwdriver touched the screw.
For the 24 movement that still has the broken screw end in it, I will try to get that out after I get the lever and screw installed in my working 24.
And yes, I will install the crown/stem AFTER I have the lever and screw in place on the plate. Again, thanks for your help- i really appreciate it!!!  Will let you know when I get things back together.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
