Timex 24 setting lever
Haboy
Setting lever screw broke on my Timex 24 movement. I have another working 24 but in need to install the setting lever and new screw which seems somewhat impossible. Is there an easy way to get the lever and screw inserted into the hole?
Hold the setting leaver exactly in place with rodic (or similar), position the screw with tweezers, and screw in place.
... or..
Position the lever with rodico, position the screw with rodico, screw in place.
It is fiddly. I presume you removed any remaining parts of the broken screw.
One other thing that occurs to me.
Fit the setting lever (443) and the screw (5443) *BEFORE* you fit the stem and crown.
Once you have it fitted, screw the screw right down, then back off by about 2 1/2 turns, then fit the stem under the tab that operates the lever and position it correctly. With the crown/stem in position, screw the screw back down till finger tight, and prove the lever/crown/stem is operating correctly, then tighten the screw completely.
Attempting to fit the setting lever, crown/stem and screw all at the same time is a much more difficult (and unnecessary) task.
Edited by AndyHull
most times the broken screw will be accessbile from the dial side of the movement.  I use a pair of fine tipped diaginal cutters to grasp the screw and slowly turn it out of the hole.
TIP -  Apply some watch grease to the bottom of the set lever to hold it in place.   Line up the holes and with tweezers, drop the set screw into place.  The turn the screw about 2.5 turns.
Thank you AndyHull and JerseyMo for responding with really helpful instructions!  You guys rock!  i have to get some rodic to help hold these two little mini-monsters in place. I was trying to use a small bit of sticky-tack but it didn't hold well enough.  I would get the screw into position but it would fall over when the screwdriver touched the screw.
For the 24 movement that still has the broken screw end in it, I will try to get that out after I get the lever and screw installed in my working 24.
And yes, I will install the crown/stem AFTER I have the lever and screw in place on the plate. Again, thanks for your help- i really appreciate it!!!  Will let you know when I get things back together.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
