WWW Eterna sucked me in.
luiazazrambo
14 hours ago, watchweasol said:
Hi   Nice and tidy job  you must have an in exhaustable sullpy of pallets.
Thank you.  🙂This very week I visited one of the recycling center with my pallet buster from Screwfix because I used it that much with heavyweight hardwood pallets that I had to buy another one, I straightened the old one. Beside of it there was a bucket full with used nails I pulled out of them, difficult to lift because of its weight. I have a trailer I load time to time with free pallets coming from FB marketplace. Some of them are only good for burning but some of them are really nice straight and clean, some of them are bulit to transfer heavy industrial equipment and they are hardwood. The crates are also hardwood and the wood they are made from usually have a nice texture. Of course the wood has the nail holes but it's easy to live with it, sometimes it even looks good.
19 hours ago, luiazazrambo said:
Custom made boxes for my watch crystals. Not 100% perfect, but it was my first try and apart from the base plywood it is made out of pallet wood again.
Loving your work and will try to imitate it ASAP. Luckly, beside an endless pallets supply I have a joiner nearby which I can coerce into planing and other operations that aren't very easy for a total amateur.
I always wanted one and I always knew that there is no space for it... I bought it anyway... so far I could not come up with a sensible idea as where to put it... Both of its locks are made in the USA maybe the whole desk was made there. One of its lock is not working, so today I became a locksmith too. 🙂 If you close the top it locks all of the drawers, both sides and the middle one too. Very very nicely made.
Edited by luiazazrambo
EB8420 finished casing it recently
This is a practice watch. I got a tray of EB8420 movements without balance wheel, a tray of EB8492 with balance wheel but without mainspring barrel and a box of new EB8420 dials. Now the balance complete is interchangeable or it is just a maybe because i could not set the beat to 0 ms as I already hit the balance cock and cannot move the little arm any more... maybe I need to play with the HS colet now. Anyway I purchased a tray of EB8420 too plus found a set of scrap hands in the scrap box. Unfortunately I have no dial rest and I dont know how to source it and where to find good looking hands. I tried to take apart the pushers to completely clean the case but the pusher screw glued or "locktited" in and when i tried to turn the screw i just broke it of... so I tried the other pusher and I broke that too... ok lets take another case all looked good for a while and then one button just fell off... i did not even touch it/push it.. the screw again was broken again at the same place, where it goes into the pusher.... two cases wasted... (dont think i can find pushers individually for this case/ cousins do not seem to have them) anyway it has a nice performance apart from the non 0 ms beat error. (as far as i remember it was around 0.5ms)
These are also ready a nice little Westclox and a Laco with Durowe 422. They are on a test run at the moment.
https://17jewels.info/movements/d/durowe/durowe-422/
  • 2 months later...
Just now, watchweasol said:
Nice old machines , what was the problem with it
The screw of the back of the electric panel holding the microphone plug became loose and both wire soldered to the plug snapped as the plug could turn around and around. It was relatively easy to sort, but then it still did not work. I got a number of microphones coming with it, I picked up two of them to test the micromat and the micromat didnt do a thing with any of them, turned out that both "microphone" was faulty. I managed to sort one of them, but the sensor in the other one snapped into half. I got some sensors not equivalent to the original, but I am going to try to use one of them as a replacement. In the package I got a Vibograf too, but it is still in the attic. I might bring that one down too soon.
I brought my Greiner Vibrograf Record down from the attic. It would not print, already figured out that its switch is faulty but unfortunately it does not stop it working. It is always on. What is amazing is that I contacted Greiner and they sent me a Manual and a circuit diagram within an hour!!! Valves! 😍 😅
Record_Schaltplan.pdf Record_Manual_E.pdf
Lol . A man after my own heart mate. Why buy it when you can make it how you want, you've even tongued the seperators in👍. I have the same chop saw somewhere.
Great for garden furniture and feature walls. Nice one Lui, i love to see recycling mate.
Initially missed these posts.great work lui. I wouldn't have worried about the 0.5 beat error, acceptable for this age and movement. 👍
Edited by Neverenoughwatches
My last toy I received with the same shipment:
I took a picture of the cover, content and the introduction of the book I bought in the British museum. Have a look at it, an incredible collection with more than 4500+ pieces a lot of them with great importance. (the pages didnt fit into my scanner, hopefully readable)
original_edf7d305-7929-4ccc-86cb-9ac765ac4678_IMG_20221008_140808_HDR.thumb.jpg.609f9ab369b1a7b307dd26fec31a944b.jpg
original_49f74323-5089-45ea-b659-c113b7ec01bf_IMG_20221008_140826_HDR.thumb.jpg.9b06ccd5047f19f338816c3a7360edd7.jpg
original_d90e1c7e-014b-4a6d-81f1-d3eae09b6473_IMG_20221008_140849_HDR.thumb.jpg.f7099e4657faf0e487408a77dc5609ab.jpg
original_21abfc15-af9c-4d3e-af66-d8da0e8ff82e_IMG_20221008_140908_HDR.thumb.jpg.df22d3bd3c5ecc080e7b059acc09789c.jpg
original_af20da90-d548-42dc-b296-20e47c74c9eb_IMG_20221008_141009_HDR.thumb.jpg.f58157753c824be640bcbd3545a98cda.jpg
original_a627ac16-de60-4295-95c0-a21f9c593041_IMG_20221008_140940_HDR.thumb.jpg.e61949de93eb7b69fcd42a0bf2653d79.jpg
Not sure if anyone wants it, but this is how the old like BCL fancy shaped crystals looked like in the past, this table is based on the original print printed in April 1981, 300 variations, 11 more compared it to August 1972. If you want the excel/ods file message me and I send it to you.
Sony TC-K61
Got this with a Thorens TD 160 record player together, unfortunately it did not do anything, it had watch issues. No lubrication at certain places or it had old lubrication acting as glue. So it was cleaned up and re-lubed with watch oil and molykote dx grease it was a bit tricky to take it apart but all functionality is restored. It did not play at all and there was no rewind or fast forward. With a pair of headphones I can enjoy 80s music again 🙂
One of my favorite activity is to reuse pallet wood, managed to do many thing out of them around the house and for the watch/clockmaker hobby, but this guy is on another level:
My plan was to make something like him and I more or less have the components for it however I came across of this and could not resist even though it was a bit pricey. Full with toys, including horological tools. And some withworth thread gauge for every day usage. 😄
Would anyone know what this tool is?
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
