Banged up Seiko SRB43J1
MattiSenturk
Hi! I was wondering if anyone could help me out. I bought a bit banged up Seiko cocktail time what could I do to remove scratches from it? I ordered some polywatch after some research as it proved itself quite usefull for the glass, but I was wondering what should I order/use to use for scrathces on metal parts or what would you do? ty for any tips!
That is surprising, as that product is specified for plastic / acrylic crystals, but your watch is has an Hardlex (hardened glass) crystal.
Edited by jdm
But will it work, what do you think? I saw someone fixing some olders seiko glasses with it (they seemed to be made out of the same stuff)
10 minutes ago, vinn3 said:
   i have never  tryed to replace a Hardlex with an acrylic .    would you have to re machine the bezel.    i'd like to do that.    vin
No I would try to do just a tiny coverup job, scartches are very light and it could be done without taking anything apart
No. For scratches on glass you need first wet paper on a rotary tool, then finish with diamond paste. Many thread on the subject here.
Well there did go my hope :D luckily the scratches aren’t that noticeable in the glass I guess I will just use some cape cod polishing cloths for the damaged metal and get saphire changed to the glass when I service it?
Polishing cloth may be good for what collectors call "hairlines" but will do nothing to scratches. As Nucejoe correctly indicated above, use the search function to learn how that type of repair is done.
You can't replace your watch high dome crystal with a sapphire because these are not manufactured in that particular shape. That is also the reason why Seiko didn't originally fit one on the Cocktail Time, unlike the other SARB line models.
Okay thats intresting, I was hoping to uprage to sapphire and I was talking about scratches on metal parts. But I also saw a ad for something called ”scratch genie” could it do the job?
    was it silocon oxide that came before diamond paper?   in any event,   you should look up various methods.   vin
Take a good picture in the current conditions, apply the miraculous product, then picture again.
We'll talk then.
37 minutes ago, TheFixer said:
Just fit a new glass.
Well, as mentioned above that is a special shape glass, the original could be in excess of USD 50, if you can find it.
Fortunately when using the proper techniques crystals can be polished to perfection.
Yeah I’ll gather up info and search some ways to try if it all goes wrong I’ll just support my local professionals and let them put brand new one
Isn't difficult to polish a glass when using the proper tools, material and technique. To be on the safe side practice on something other watch first.
If you give a Seiko watch to a local repairer expect them to complain they can't get parts for it, as Seiko USA sells only to the dealers and centers having an account. But mov't parts are easy to get.
I live in Finland and my friend named one place that has these cocktailtime glasses available but yeah I’ll propably give it a go first myself. Are there some tools that you recommend/ you use yourself for the job?
Have a search for "polishing crystal" or similar terms.
How much does it cost to have someone polish such a glass inc materials and labour.
Full guess but here probably around 50-90€ but I think they will want to change the glass straight away because of the amount of labour needed. Kinda sucks tho cuz the watch is worth like 300€ max
Well, this being a (mainly) hobbyist repair forum -as opposed to a collector's- the idea is to share and and teach how things are done. And polishing is a good example of something easy and rewarding.
Yeah I came here just for that tips for taking care of things in more sustainable way in long run! Thank you very much for your toughts and opinions btw! Such a nice community you have here!
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
