Ronda 1113 mechanical movement
Paulevs
Old movement probably been sitting idle for long time, I soak the movement in naphta   for a day or two or apply penetrating oil which  reduces risk of breaking screws . Take extra care with pin pallets. Not worth buying parts for, I got some parts to it.
For a newcomer the skills you'll be needing to pick up are to do with dexterity in handling small parts with tweezers, undoing screws and making sure the screwdriver blade doesn't slip, cleaning parts, reassembly, putting the balance back in place etc. etc.
You don't want to be starting out with expensive movements and so pin-lever designs (like the Ronda 1113) are ideal as they'll introduce you to the makeup of a watch and allow you to practice the above skills and can be picked up pretty inexpensively.
Initially I'd advise getting hold of a working movement. This way you can concentrate on the important dexterity skills and disassembling and reassembling with the aim of the watch still working afterwards! The danger with picking up a non-working movement - especially on cheaper movements with limited shock protection and jewel counts  - is that the balance staff can be shot or parts worn which then means you have to get other movements the same for spares or new parts which outweigh the value of the movement.
So in summary I'd say the actual movement you chose is less important than getting something that works already and/or where there is good availability of other 'spares or repairs' movements the same so if something goes wrong you have a parts backup source.
Edited by WatchMaker
So in summary I'd say the actual movement you chose is less important than getting something that works already and/or where there is good availability of other 'spares or repairs' movements the same so if something goes wrong you have a parts backup.
Thank you for reply. the Ronda 1113 is sold as new old stock. Working and at only £8.50. I will pick one up and practice. Thank alot.
For a newcomer one thing to be careful of is squeezing the tweezers too hard when holding a small part, quite often the part will 'ping' off at great speed involving much searching. Basic stuff, but you don't always think of it at the time.
Thanks for all your help.i have only changed crystals,hands and whole movements before so thought I'd have a go.
Therefore, see that you always have a magnetic strip around, to find the small pieces on the ground again.:biggrin:
https://www.toolspecialist.be/688-flexible-magnetic-strips-2-150mm-e-magnets-688?___store=be&gclid=EAIaIQobChMIopfQv7We5QIVguR3Ch34KQ4gEAQYECABEgJLvfD_BwE
And don't forget them to demagnetize afterwords.;)
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
