Vintage diver watch
deni2s
Bought this vintage MILJONÄR Swiss Made 1970s old diver wrist watch 17 Jewels couple months back from ebay very cheap (like 50 euros with delivery). Just liked the looks of it and thought I might get it back to working shape, so I can use it as my cheap tool watch for rainy days and just to get involved into watchmaking a bit.
Watch was not running at all, glass broken, unable to unscrew the case back (well, that explained the price).
MILLJONÄR is some Scandinavian market brand, usually they are non-expensive watches with AS movements. There are quite a lot of them around, but I couldn't find online another one divers watch. This one had AS 1686 movement with rotating bezel and claims to be 20 ATM waterproof on case back.  40 mm diameter.
Tried to open case back myself, no luck. Asked local watchmaker in Helsinki - no luck. He suggested oiling the case back for a week using WD-40 and try later - no luck. As last resort he suggested gluing with superglue to watch case some big nut, so I can use some wrench to unscrew the case.
Went to Riga, Latvia, asked watchmaker here to try to open it (they bragged they are best watchmakers in 8000km radius), he glued something to watch case, opened and cleaned reminds of glue with ultrasonic in less than 10 minutes, while we were talking.
After that I disassembled the movement (stripped the lefty screw on crown wheel due to luck of experience), cleaned, oiled, assembled - it started to run pretty well. Ordered new set of screws from ebay, got all of them, except the one I needed (for crown wheel) - seller forgot to add it to package. After finally receiving it, I realised it's not the screw which is stripped, but the bridge over mainspring needs to be replaced. So ordered that from the same seller, replaced and watch was almost completed.
On next trip to Riga got glass replaced and bought some non-expensive nato strap on ebay.
Quite happy with end result and experience gained during the process!
17 hours ago, anilv said:
Great job! I is it a stainless steel case or base metal?
Also does the crown screw-down?
Anilv
It's a base metal, no screw-down crown. Nothing fancy. I would say that's a watch which looks good enough with all the scratches and usage marks to wear it daily, and cheap enough to not worry about it at all :).
Yes, the name means that (that's in Swedish).
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
