Merry Christmas From The Philippines!
tkdwarrior
I think I have a twin of your watch, rebuilt recently from a non running ebay purchase. I kept the bezel insert since it shows some character and harmonizes with the overall looks.
BEFORE:
AFTER:
In any case, I wouldn't know at this point from the SKX reference, but it is (still is) and 7S26-0030!
Welcome to the forum twin Seiko owner! :)
Cheers,
Bob
BEFORE:
AFTER:
Cheers,
Bob
Hi there yup they do look the same to me too but mine says 7s26-0020 instead of 7s26-0030:)
But hey thanks for the welcome:) And that is really great what you did with your watch:)
Here in the Philippines we have some of the great watch restorers around, especially with seiko. I am sure you are familiar with Mang Loy?
Here in my province there is a watch repairer in town who buys supposedly brand new casings for seiko dive watches and fits them with overhauled 7s26 movements. And you can't almost see the difference from the original. Don't know where they get these "brand new cases". But testing these cobbled pieces to specs like it's water resistance rating of 200 m it is a wonder that these could match the originals. Really great craftsmen these people are:)
@blacklab: That is correct Roger. I have bought a lot from him lately. You can say it is my source of training materials. :)
@tkd: Sorry, I'm not familiar with the person. I'm sure those restorations are something and a wealth of knowledge if they ever disclose/publish what they do to fix and restore. In any case, since yours is a 0020 (bigger case) I got its little brother (medium case) :)
Cheers,
Bob
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
