Poljot watch dating!
I believe that "Kamhen" simply means jewels, so 16 Kamhen just means 16 jewels.
The movement is actually a ZIM, and I think it is a 2608. The Russian watch caliber numbers actually describe features of the movement. The first two digits give the size in mm, so yours should measure 26mm, the second two comprise a code for the complications that the watch has like center or sub-seconds, date, shock protection etc.
According to Ranfft production started in 1955. The set lever had a screw until 1957 then changed to a push pin, and in 1959 the crown wheel changed from 2 screws to 1 screw.
Yours has a push pin set lever, so after 1957, and two screws for the crown wheel, so before 1959.
Many thanks for the info marc!
Would you know anything about it value mate! It’s not my watch, it’s a friend i know, he’s into costume dressing up! He likes to dress up with stuff dating from the right era!
Like most Russian watches, if it is serviced and in good working order it is worth far more than you could sell it for.
Value wise if you look on eBay you will find this sort of Poljot going for any where between £5 and £25 depending on condition, it could fetch more but not very likely. Russian watches tend to be very under rated though (in my opinion)and consequently demand far lower prices than their Swiss equivalents.
They are quite capable movements though, and well worth picking up if you're into solid reliable engineering. Unfortunately a lot of them are rather let down by their cases.
Thanks marc! Much appreciated mate!
    good refural.    vin
      I might try buying a watch from e  bay.    vin
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
