Poljot watch dating!
I believe that "Kamhen" simply means jewels, so 16 Kamhen just means 16 jewels.
The movement is actually a ZIM, and I think it is a 2608. The Russian watch caliber numbers actually describe features of the movement. The first two digits give the size in mm, so yours should measure 26mm, the second two comprise a code for the complications that the watch has like center or sub-seconds, date, shock protection etc.
According to Ranfft production started in 1955. The set lever had a screw until 1957 then changed to a push pin, and in 1959 the crown wheel changed from 2 screws to 1 screw.
Yours has a push pin set lever, so after 1957, and two screws for the crown wheel, so before 1959.
Many thanks for the info marc!
Would you know anything about it value mate! It’s not my watch, it’s a friend i know, he’s into costume dressing up! He likes to dress up with stuff dating from the right era!
Like most Russian watches, if it is serviced and in good working order it is worth far more than you could sell it for.
Value wise if you look on eBay you will find this sort of Poljot going for any where between £5 and £25 depending on condition, it could fetch more but not very likely. Russian watches tend to be very under rated though (in my opinion)and consequently demand far lower prices than their Swiss equivalents.
They are quite capable movements though, and well worth picking up if you're into solid reliable engineering. Unfortunately a lot of them are rather let down by their cases.
Thanks marc! Much appreciated mate!
    good refural.    vin
      I might try buying a watch from e  bay.    vin
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
