Seiko 7s26A
TheFixer
7S26 has A, B, and C versions but not "plain 7S26". The barrel complete was changed in the B version as noted in my sheet https://docs.google.com/spreadsheets/d/1sYt_mI9c4tAPiKN3IM8lQx3NEEOyz2DMjVHx5I1_Mqw/edit?usp=sharing
Before buying be very sure that the barrel complete really need replacing. You could be spending almost the same as for a brand new and better mov't for no good reason.
Edited by jdm
Thank you.
Cousins has a 7s26 listed but not a 7s26a.
I am a big fan of the A movement as it is the best variant.
9 minutes ago, TheFixer said:
I have found an alternative spring which is cousins part no: GR2378X
0.95X.12 X400 X10.5
Ever so slightly thicker but the nearest I could find.
Check thread below about adaptability of generic mainsprings to a Seiko barrel.
In general the best approach is to leave the sealed barrel alone. While you may think that it is the mainspring to cause a Seiko watch to run poorly, that is rarely the case.
Thanks for that but the other mainspring mentioned is no longer available.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
