Seiko Mainspring Database?
jaycey
I was wandering...
As many Seiko complete barrel/mainsprings are beginning to command a kings ransom, has anyone seen or thought about an online resource for calibre/mainspring sizes when replacing just the mainsprings?
With a little care, just the mainsprings are replaceable & it would be a lot easier to look-up the spring size rather than measuring it.
I'm about to service a 4R36 so will be measuring that...
First question, how do you know that the MS is to be replaced? It is not a mandatory item at each service interval.
Now, this isn't the first topic opene on the viability of replacing Seiko MS in their sealed-for-life barrels. You can read more about that including the MS reference.
Hi @jaycey - I've not worked on a Seiko before but I still read most forum postings no matter what the topic as, assuming I can't answer a particular question, I can still add to my knowledge base!
What I've interpreted from your query and Seiko mainspring postings in general is that if a new mainspring is required then by design it should be a barrel-complete job but getting hold of these is not easy. However with some care it is possible to open a 'sealed barrel' to replace the mainspring.
In this case I would say that a ready reference for springs required per calibre is a great idea! It would be interesting to see what Seiko aficionados think.
Nail on the head exactly!
I mostly head over to the Roland Ranfft movement database when ordering mainsprings (which I replace as a matter of course with every service)
Although he has the Seiko movements in the database, he lists only the part number for the barrel/mainspring complete.
I will probably try and contact him regarding adding to those part numbers with actual spring replacement measurements.
In the meantime though, it would be great to just have 'place' where we can collate the information for him and others to feed off whilst it builds.
It will just make life a lot easier for all watchmakers in the future.
20 hours ago, aac58 said:
WatchGuy has a mainspring database here where with some Seikos, although not all are listed. Sometimes you have to figure out what movement have the exact same spring.
That's perfect & exactly what I was looking for, thanks!
Anyone else who's changing Seiko mainsprings, contact WatchGuy if you replace a spring not listed. The 4R36 should be added soon:)
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
