Seiko Mainspring Database?
jaycey
I was wandering...
As many Seiko complete barrel/mainsprings are beginning to command a kings ransom, has anyone seen or thought about an online resource for calibre/mainspring sizes when replacing just the mainsprings?
With a little care, just the mainsprings are replaceable & it would be a lot easier to look-up the spring size rather than measuring it.
I'm about to service a 4R36 so will be measuring that...
First question, how do you know that the MS is to be replaced? It is not a mandatory item at each service interval.
Now, this isn't the first topic opene on the viability of replacing Seiko MS in their sealed-for-life barrels. You can read more about that including the MS reference.
Hi @jaycey - I've not worked on a Seiko before but I still read most forum postings no matter what the topic as, assuming I can't answer a particular question, I can still add to my knowledge base!
What I've interpreted from your query and Seiko mainspring postings in general is that if a new mainspring is required then by design it should be a barrel-complete job but getting hold of these is not easy. However with some care it is possible to open a 'sealed barrel' to replace the mainspring.
In this case I would say that a ready reference for springs required per calibre is a great idea! It would be interesting to see what Seiko aficionados think.
Nail on the head exactly!
I mostly head over to the Roland Ranfft movement database when ordering mainsprings (which I replace as a matter of course with every service)
Although he has the Seiko movements in the database, he lists only the part number for the barrel/mainspring complete.
I will probably try and contact him regarding adding to those part numbers with actual spring replacement measurements.
In the meantime though, it would be great to just have 'place' where we can collate the information for him and others to feed off whilst it builds.
It will just make life a lot easier for all watchmakers in the future.
20 hours ago, aac58 said:
WatchGuy has a mainspring database here where with some Seikos, although not all are listed. Sometimes you have to figure out what movement have the exact same spring.
That's perfect & exactly what I was looking for, thanks!
Anyone else who's changing Seiko mainsprings, contact WatchGuy if you replace a spring not listed. The 4R36 should be added soon:)
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
