help ID patek philippe watch
Hello,
I came across this watch but I know nothing about it and couldn't find anything about this particular watch online, I did learn that this brand is really good and expensive.
do you have any information and is it worth buying?
Edited by Ammar
4 hours ago, Ammar said:
so it's experience, I guess I'm gonna have to get scammed a couple of times in order to get this experience ^_^
You aren't scammed paying the price of a genuine item, and that is quite rare. So e.g. the watch above is $40, how can one dream that is genuine?!? Buying it you're however an accessory of the crime of counterfeiting.
One thing that tips it off (aside from the general look and finish, but that takes some experience) is that Patek does very few watches in stainless steel, and when they do, they do the whole case in stainless. They wouldn't have a precious metal watch with a stainless steel back. Also, stainless Pateks are quite sought after, and easy to Google, so little chance of finding one for a few bucks.
Here is my take on that watch.
Dull appearance of case, poor dial quality, cheap hands, fake moonphase, the knurling on the two "crowns" don't match, the crystal is dull and looks like cheap window glass rather than sapphire, the second hand has fallen off, the dial indices are poorly formed and look like plastic, the case back is poorly engraved... the price is stupidly low, the strap looks like it is made from cardboard... save your pennies for something more appealing.
Compared with this, where everything is sharp.
This is either genuine, or a much higher quality fake (in this case, it is almost certainly genuine), and therein lies the real problem.
Poor fakes are generally pretty easy to spot, but there are a lot of much higher quality fakes out there.
Then there is this. An image straight from the manufacturer's own web site.
Again you can see that everything matches, the dial face looks stunning, the indices are well applied, the whole effect is balanced and even the strap oozes quality.
Edited by AndyHull
And I've heard that seller has bad breath :biggrin:
These are slam dunks threads really.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
