help ID patek philippe watch
Hello,
I came across this watch but I know nothing about it and couldn't find anything about this particular watch online, I did learn that this brand is really good and expensive.
do you have any information and is it worth buying?
Edited by Ammar
4 hours ago, Ammar said:
so it's experience, I guess I'm gonna have to get scammed a couple of times in order to get this experience ^_^
You aren't scammed paying the price of a genuine item, and that is quite rare. So e.g. the watch above is $40, how can one dream that is genuine?!? Buying it you're however an accessory of the crime of counterfeiting.
One thing that tips it off (aside from the general look and finish, but that takes some experience) is that Patek does very few watches in stainless steel, and when they do, they do the whole case in stainless. They wouldn't have a precious metal watch with a stainless steel back. Also, stainless Pateks are quite sought after, and easy to Google, so little chance of finding one for a few bucks.
Here is my take on that watch.
Dull appearance of case, poor dial quality, cheap hands, fake moonphase, the knurling on the two "crowns" don't match, the crystal is dull and looks like cheap window glass rather than sapphire, the second hand has fallen off, the dial indices are poorly formed and look like plastic, the case back is poorly engraved... the price is stupidly low, the strap looks like it is made from cardboard... save your pennies for something more appealing.
Compared with this, where everything is sharp.
This is either genuine, or a much higher quality fake (in this case, it is almost certainly genuine), and therein lies the real problem.
Poor fakes are generally pretty easy to spot, but there are a lot of much higher quality fakes out there.
Then there is this. An image straight from the manufacturer's own web site.
Again you can see that everything matches, the dial face looks stunning, the indices are well applied, the whole effect is balanced and even the strap oozes quality.
Edited by AndyHull
And I've heard that seller has bad breath :biggrin:
These are slam dunks threads really.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
