Felsa 4033
Hi all - just realised I haven't been on the forum for 2 years! Time flies...
I have a watch on my bench with a 13''' Felsa 4033 movement in it. Can't find any info on the movement at all...wonder if any of you folks have heard of it or if there are equivalents or other variants. Not even Ranfft.de seems to have info on it!
It's an automatic movement with a little spring clip holding the oscillating weight on - i need to replace that, and put a new mainspring in.
Thanks!
It's likely it's another modification on the 400x series (http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Felsa_4009) that's not listed on ranfft etc. since a look up on a site like Cousins for Felsa 4033 parts then lists parts from the 4000, 4009 and so forth as compatible.
If you grab the parts diagram for one of these related Felsa movements (e.g. https://www.cousinsuk.com/PDF/categories/2772_Felsa 4009.pdf) hopefully you can identify the part you need. Part 1475 I note is described as the 'bolt spring for oscillating weight'.
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
