Ok guys, I’m struggling abit here with my gravers. I start on a course (ish) stone, then onto a fine oil stone then onto Arkansas stone, all using 3 in 1 oil as lube, I get reasonable results, very sharp but only for about 5 -10 minutes of work on blued steel. Not working them hard either, just getting a little despondent with the amount of time im sharpening as to time spent turning.
How do you sharpen and how long does the sharpness stay??
That time is not out of the ordinary on blued steel. You get used to doing a quick touchup every few minutes on the arkansas. Before I switched to tungsten carbide gravers I would have several ready to go, rough, semi finish, finish, could make it through a staff or stem without sharpening usually. Then hit them all on the stone(s) after.
I was complaining about the same thing to couple of watchmakers I know.  One pointed out there be a big variance in the quality of the steel and temper so that might be part of it.  I agree with nickelsilver, life is a lot easier using carbide cutters....but imo the easiest is to harden and temper the part after machining.  Your HSS cutters will last a lot longer in annealed O1.  Which ever route, sharpen a bunch at time,  get them really really sharp, and grab a fresh one when it starts to feel dull
Edited by measuretwice
Cheers for the replies guys, I was wondering if I was being to heavy handed, I was taught by my father how to use a lathe many years ago (machinist) that obviously had a cross slide on it. Never once did a dull a tool on that.
I think I will try some of the carbide gravers and see how they fair, I think I’ve had enough practice on sharpening gravers now
Two things, on your fathers lathe odds are you weren't trying to cut hardened tool steel, and secondly, how sharp or how fine the edge needs to be a is a function of how small the depth of cut is.  taking a few tenths of a thou DOC needs an edge magnitudes finer than ten thou....and it also only stays that fine for a while
  "compound  lathe" - turning with a threaded feed.  gravers  ---  totally difernt .   carbide should be sharpened on a "green stone"  grinder.    vin
On ‎10‎/‎21‎/‎2019 at 5:32 AM, measuretwice said:
a green wheel is only for very rough work and will usually leave an edge with lots of chips that you'll need a diamond wheel to get rid.  Best to start with the diamond wheel imo....that's one area where low cost imports are really a great thing.
   green wheel works fine for me.
Just adding that making carbide gravers yourself is quite easy, from broken drills or endmills etc. There are apparently many types of carbide, and the commercial ones that I have are of a darker color than the homemade ones.
In the picture below, the two on the left are commercial, by Eternal tools -- pretty expensive. The rest is home made. They may look rough and crusty, but that's just the non-acting surfaces. The far right one was an experiment (very easy to make), and is actually my go-to graver for hogging hard steel. It is very hard to damage.
If you start using carbide gravers, you need to be reasonably adept at using normal gravers, since any mistake will chip the graver or snap the tip right off. You can regrind it of course, but that's more troublesome because of the diamond tooling.
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
