Sorry, I forgot to introduce myself
desuty
I went ahead and created an account to post my question right away. But first thing last - I'm just an admirer of mechanical watches. As Frank Seuss - a watchmaker from downtown San Francisco once told me, "at least your watch ticks, compared to most watches these days" - the intricacies of mechanical wrist watch movements fascinate me. I bought few watch repair tools last week; however I'm too skeptical to fix watches by my own - without any formal training. That being said, I'm good at fixing things. Perhaps I might learn a thing or ten from this forum.
Just reach to the drawer and completely take apart a quartz watch with a $15 repair kit, put it back together if it runs with no lost or damaged parts you're on the good track, if not some more effort is needed.
Welcome! You most certainly learn from this diverse group of horophiles and experts. Welcome home!
    • This is a very valid point and a subtlety that I was unaware of until fairly recently, learning all the time, the video below explains this point well:
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
