Fossil Watch Fix
My father in law sent me a Fossil watch my wife and I had given him as a gift. It is a model ME3052 and he told me it was not working.
Upon receiving the watch, I immediately noticed the rotor was loose inside and banging around everywhere. Apparently it came loose after the watch fell.
I opened it up and the rotor had caught in the escapement, damaging the balance spring and wheel. Since the watch had sentimental value, I decided to fix it.
Obviously the movement had no model number or any marking of which I could make out the movement model. I knew it was a Chinese skeleton, of which there are a million models online.  After several days of research and almost giving up, out of pure luck I glanced at the backside of the dial and saw TY2723 marked. I typed it online and bingo! That was the movement model.
I could only find two places which stocked it and decided to go with Esslinger. After the movement arrived I assembled everything. I was almost done when I placed the crown and it wouldn’t go in. After some tinkering it finally went in. I was happy, but when I flipped the case, the winding gear was loose inside the case. Apparently it dislodged when putting in the crown.
I decided to give it a shot and fix it. Mind you I had never taken apart a movement, let alone a skeleton stem assembly. It was difficult and I assembled it wrong several times before finally understanding how everything works. It was good that I had the older movement, cause I lost some tiny screws in the process. I think the hardest part was getting the little spring which drives the clutch lever in place.
Anyways, I put it all together and the watch works great. :)
Teaching point: Don’t take on a skeleton movement as your first fix. Hahaha
Just wanted to share the experience with you guys, cause I was so happy I was able to fix it. Below are some pictures.
Hi you have done well getting that sorted. Its this the start of a new hobby ?  The TY is a seagull chinese movement they are usually based on ETA movements. Unusual to see one of these in a fossil as they usually use the genuine ETA movements. Was the watch a replica or the genuine article.
Hi. Thank you. I am really getting into this hobby. :)  I bought the watch at fossil store so I guess its the real deal. I did read somewhere that Fossil was now using Seagull movements, but I can’t ascertain if this is true.
Hi  If it came from the store it must be genuine, probably Fossil using cheaper chinese units, they will certanly save a bob or two but will it detract from the brand . I have repaired fossil watches and they did use the ETA units. Some of the chinese units are quite acceptable now although the finish is not as good as the ETA.  I noticed you had a problem refitting the stem, On the ETA units pull the stem out to 3rd position then release If not the keyless work displaces and you have to take te dial and hands off to refit might be the same on the clone unit. Not found a tech sheet for it yet.
Thank you for the advice. That’s what happened to me. The kelyless works came undone with the winding gear displaced completely.
Here is a foto of the backside of the dial with the movement model.
I did this this big boy today and it is ETA-free, but they are reinventing (and patenting) the meca-quartz concept :biggrin:
The mechanical portion moves only the "petite trotteuse", and I even regulated it a little, while feeling a bit stupid in doing so. Amazingly, it takes 25 jewels to accomplish this less than monumental task.
They must have a scarcity of adhesive at the dial factory, because three indexes and the seconds chapter ring had left their place. The minutes hands barely stayed, being made without a tube.
Awesome!!  Very cool. A kinetic movement from Fossil. Would like to get one of those. Thanks for sharing!!
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
