Breaking grease
PeterS
My first time with autos. I believe that autos require breaking grease on the inside of the barrel wall. I looked at the service sheet but it doesn’t show oiling of the barrel wall (NH36). The greases (Moebius) I can see:
8212 – aluminium walls
8213 – brass walls
8217 – large barrel walls (guess - pocket watches, alarm clocks?)
How do I tell brass from aluminium without scraping the barrel to see what is under the plating?
One more important question. If I grease the main spring with say 8200, surely this will cross contaminate with the breaking grease on the barrel wall. Is not greasing perhaps the last inch of the spring the solution?
The service manual specifies replacing the entire barrel assembly at each service. I dont think Seiko intended for these to be oiled outside of the factory. I always thought these are solid steel on Seikos but I could be wrong. I don't think it's a big deal if there is a bit of cross contamination here. There WILL be cross contamination no matter how careful you are in this case.
As mentioned already by all means don't mess with the barrel complete. It is not needed, and your will do more harm than good.
I'm attaching an image from the service bulletin for your watch. As the others have specified in the service bulletin it's a barrel complete. This is a relatively inexpensive watch I doubt that there's any parts available and trying to get a new mainspring for this would be hard if not impossible. So it really would be best just to leave it alone.
Then no need to worry about cross-contamination with 8200 because if you were servicing the mainspring barrel you would be replacing the mainspring which would be the preferred method. Then new mainsprings are supposed to be prelubricated which is why even if you have a tech sheet that shows the breaking grease there is no lubrication applied to the mainspring itself only the outer barrel wall and the arbor.
Thank you for your answers.
This movement is purely for me to train on. Just like I used the 6497 and took it apart countless of times this one is going to be the one with extra complications that I want to use for learning. It does not matter if something goes wrong with the barrel complete, it’s never going to go in a watch.
I would like to take the barrel apart. I’ve seen Mark servicing the S726 and he uses breaking grease but does not mention which one and I don’t know which one to use. Any suggestions?
We must also give the complete, info so:
  1. That the barrel complete has to be replaced at each service isn't a fixed rule and certainly is not mentioned in the Seiko document. It should be replaced when the amplitude has dropped significantly and all the other factors influencing it have been excluded. In practice that can be decades of continued use. And the watch is left unwound the mainspring will not deteriorate at all.
  2. The NH36 is an inexpensive mov.t but virtually all parts are made available. For example the above mentioned barrel complete cost £16.90 from Cousins UK. That is a significant portion of the complete mov't at just £30.95.
  3. About opening the barrel see below by our Host Mark Lovick
  4. When doing the above the replacement mainspring is GR2378X.
Then why don't you practice with a mov't barrel that is designed to be opened and closed instead? So your skills will develop toward normal operation rather than something else.
Thank you guys. Yes, it would have been easier if I had another movement that’s suitable for it however this is what I have now.
I’ll use the movement for learning, keep the barrel as it is for now and I might come across a thread/article where someone has successfully applied breaking grease to the wall (no doubt Mark will cover it in level 4). If not I could try different greases and see what results I get. From what I read I’d probably start with the P125.
Is this the same case for other Seiko movements? 7s26, 4R35, 6R15 and the older calibers?
All these have virtually the same sealed barrel. Do not open unless there is a proven benefit.
For older mov'ts consult the relevant service sheet.
44 minutes ago, PeterS said:
I wonder whether I could use the Seiko S-3?
This is the description:
Seiko S-3 Silicon Grease
I don't think there is any silicon in this, and the description is wrong.
Personally I would not spend £18.95 + VAT for something that is never going to go in a watch. And I would use proven Moebious products amentioned above for Swiss watches with a mainspring meant to be serviced.
I dont think it's too big a deal. I doubt there's any magic sealed inside. Seiko probably wants us to treat these as consumables to expedite the servicing process and maybe make a few more bucks from new barrel orders. We can open these if we really want to. Just lubricate these as any other barrel. There are no unicorn guts inside. I've opened a few and they come apart and go back together just as easily as any other.
Edited by CaptCalvin
6 minutes ago, CaptCalvin said:
I dont think it's too big a deal. I doubt there's any magic sealed inside. Seiko probably wants us to treat these as consumables to expedite the servicing process and maybe make a few more bucks from new barrel orders. We can open these if we want to. There are no unicorn guts inside. I've opened a few and they come apart and go back together just as easily as any other.
Of course these can be serviced, nobody said otherwise. In that sense above I linked a posting with the basic how-to, and a replacement mainspring reference. That being said Seiko did the right thing in making orderable the barrel complete only, here's why:
  • They are actually built more tightly and less strong that a traditional one,s I know of at least of one beginner that posted having broke it while trying to open it. I've sent him a free replacement BTW.
  • Being more tightly built, even if not technically sealed, makes so no external agent can enter. So the issue of meeting a "filthy dirty" mainspring is gone.
  • Considering that the important point above is out of the equation what is exactly the remaining reasons left to service it?
  1. That the braking grease has lost effectiveness and the mainspring slips while winding. But in fact that is not only a function of the "semi-braking" agent, but mainly of the bridle design, materials used, and mainspring strength. I can tell you that Seiko did good in that area, as I've never seen faulty Seiko barrel.
  2. That the mainspring has lost it's elastic properties after much, much use.  Again, I've never seen one so far. Personally I've replaced one on a 7S26 because I blamed insufficient amplitude to an old MS. Guess what, the new one didn't made any difference.
Hmmm it is true that I remember these taking more force to pop open. For the record I dont recommend messing with these barrels. But if NH35 is all you have and you want to start tinkering it's not the worst idea to start on these being as inexpensive as they are. I myself started on NH35s. I find them relatively sensitive to proper lubrication as well so it really conditioned me to be precise with oil application.
Correct, I've found myself a good improvement when I've started using 9415 on the pallet stones.
Exactly, the NH36 is cheap and I thought it would be a good starting point.
I will not take the barrel apart, for now. I want to get used to the extra complications I’m not used to and I want to see the results after reassembly. If I take the barrel apart now and the amplitude or something else is not right I will not know what the problem is unless I buy a new barrel.
After I’ve stripped it and put it back together several times and I’m confident with this movement the barrel is definitely coming apart and I want to see the results after reassembly.
Captain, what grease did you use on these?
May be of help a little.
I find that carefully using the blade of a Swann Morton scalpel helps to separate and start lifting the lid of Seiko mainspring barrels, they can be more easily damaged with a screwdriver tip for example.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
