Hairspring regulating pins
Can anyone give me advice on how best to open, close and adjust these regulating pins, before I do something irreversible? They are from an Osco 42. I have tried to turn the thicker pin with a screwdriver in the now mangled slot. I have also tried pliers. It won't budge. I Bent the thinner pin to get the hairspring out, but I suspect I don't have too many more chances to get it back into shape. I'd prefer to do as much manipulation as possible with the hairspring out of the way.
Hi the regulator pins are not meant to be bent as this will effect the rating of the watch as the gap in which the balance spring operates will be incorrect.  In your case the boot shaped leg has to turn thro 90 deg to release the spring. Some of these legs are tight, Use a screwdriver which fits the slot and place the balance cock on a firm surface and with firm pressure attempt to turn the leg. If you manage this there is just a chance you will be able to stroke the fine pin upright with fine tweezers, stroke it along its lenght carefully do not attempt to bend it straight or it will break off.
  • Thanks 2
When I get a boot that doesn't want to move I put some oil, thin like 9010, on its mounting point. Turn back and forth with (well fitting) screwdriver and they go free. Only recall one in 20 years that didn't work, old Lecoultre from the 20's.
WWsol is right about the pin, need to be really careful, the gap should be roughly equivalent to a hairspring thickness when you're done.
  • Thanks 3
Success! A drop of oil on the base boot and the head of the rivet then letting it soak for a while worked wonders! Didn't even need working loose, just turned like there'd never been a problem.
I also managed to straighten the pin to a reasonable degree by placing the tip of an oiler between pin and boot, then squeezing with tweezers. The final adjustment of the gap I will do when fitting everything back together. I don't see how I can get the gap small enough and parallel, without putting a severe dog-leg in the pin right at the bottom, but I might not have to. We'll see.
Thanks very much once again. Amazing how just having the confidence you are doing the right thing helps you do it right.
I believe both the boot and pin are usually a friction fit in the balance cock.  Cousins UK have a range of these available, so as a last resort (or necessity if you bust them!!) you could measure up the old ones before removing them and source some new ones to push in.
A final report from my side. Here's a close-up of the regulator pins in action. I think you can make out where the balance spring sits in the gap, and that the gap is reasonably small and parallel in the area it needs to be. I think I'll leave it at that. The movement has too many other issues to be a really good performer anyway, but great for practising on. Thanks again to everyone for the help and advice.14559044_Regulatorclose-up.png.728c4bff933f7acc4d1b707c44ec0e64.png
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
