Dial foot soldering
watchweasol
Hi Working on a seiko 7009A today, a bit of a wreck. Dial loose intermediate date wheel u/s, all back up and running but had to sort out the dial so I dug out the dial foot machine build a couple of years ago, as you can see by the pics it still works and no marking on the dial. It was build from readily available parts. The power source is a car battery charger which plugs into the unit. the probe is the carbon center core from a battery. I belive it goes under the heading of cold soldering, basicaly it provides an arc at the bottom of the dial foot wire where you place some flux and bits of solder. the resulting arc melts the solder and attaches the foot wire. Any body interested can find the details on the net. The origionator of this particular design was one Dirk Fassbender the details he put on the net are still there or alternativly there is a book,  Quartz watch retro fitting  by Wesley R Door, available in America but not so easy over here in the uk. I have some pictures I copied from the net that give the basics. All it is is a transformer providing the Arc not hard to build and a very hand tool to have in your collection..
  • Like 5
I haven't done any dial feet soldering, but I have done quite a lot of electronic soldering over the years.
You might also be interested in low temperature solders.
https://www.digikey.com/en/product-highlight/c/chip-quik/low-temperature-indium-solder-wire
Keeping the heat as local as possible helps, when working with sensitive components, as does careful heat sinking and using suitable fluxes to minimise soldering time.
I've been experimenting with a similar setup too, using a 10A DC power supply and carbon rod, minus the nice case. Not sure what's wrong, but I just couldn't get anything to stick to the dial, with various fluxes (resin core, electronics type flux, nasty plumber flux). It seems like the dial doesn't get hot enough through thermal conductivity via the dial foot wire.
Perhaps not enough current.  Any sense of the voltage/ current you are getting?  very low voltage high current is  the usually way to make a resistance solderer.  A great way is to take the secondary off a microwave transformer and replace it with a few loops of that super thick speaker wire some audiophiles love (little do they know it only sounds different because you've added capacitance lol).
I've got one that's half built, I used the rack and pinion from an old microscope as a way to move the pin into perfect perpendicular contact with the dial.  A sponge sits under the deal to insure the heat doesn't affect the dial face.  Pics to follow.
Oh, carbon rods are readily available in different diameters at welding supply places - just ask for carbon gouging rod
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
