Dial foot soldering
watchweasol
Hi Working on a seiko 7009A today, a bit of a wreck. Dial loose intermediate date wheel u/s, all back up and running but had to sort out the dial so I dug out the dial foot machine build a couple of years ago, as you can see by the pics it still works and no marking on the dial. It was build from readily available parts. The power source is a car battery charger which plugs into the unit. the probe is the carbon center core from a battery. I belive it goes under the heading of cold soldering, basicaly it provides an arc at the bottom of the dial foot wire where you place some flux and bits of solder. the resulting arc melts the solder and attaches the foot wire. Any body interested can find the details on the net. The origionator of this particular design was one Dirk Fassbender the details he put on the net are still there or alternativly there is a book,  Quartz watch retro fitting  by Wesley R Door, available in America but not so easy over here in the uk. I have some pictures I copied from the net that give the basics. All it is is a transformer providing the Arc not hard to build and a very hand tool to have in your collection..
  • Like 5
I haven't done any dial feet soldering, but I have done quite a lot of electronic soldering over the years.
You might also be interested in low temperature solders.
https://www.digikey.com/en/product-highlight/c/chip-quik/low-temperature-indium-solder-wire
Keeping the heat as local as possible helps, when working with sensitive components, as does careful heat sinking and using suitable fluxes to minimise soldering time.
I've been experimenting with a similar setup too, using a 10A DC power supply and carbon rod, minus the nice case. Not sure what's wrong, but I just couldn't get anything to stick to the dial, with various fluxes (resin core, electronics type flux, nasty plumber flux). It seems like the dial doesn't get hot enough through thermal conductivity via the dial foot wire.
Perhaps not enough current.  Any sense of the voltage/ current you are getting?  very low voltage high current is  the usually way to make a resistance solderer.  A great way is to take the secondary off a microwave transformer and replace it with a few loops of that super thick speaker wire some audiophiles love (little do they know it only sounds different because you've added capacitance lol).
I've got one that's half built, I used the rack and pinion from an old microscope as a way to move the pin into perfect perpendicular contact with the dial.  A sponge sits under the deal to insure the heat doesn't affect the dial face.  Pics to follow.
Oh, carbon rods are readily available in different diameters at welding supply places - just ask for carbon gouging rod
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
