Removing lume
easj369
I have not received this watch in hand yet.  I just bought it off eBay.   It was previously listed on eBay with a terrible title and then relisted.  I bid on this watch and won it.  Tonight I was looking at the listing again and saw he added to the description after I bid on it.   The hands were relumed and the dial had lume added which I think is sad    I can live with the hands being done but on the dial I already don't care for.   I do want this watch and am going to keep it.  Is there a way to remove the new lume on the dial without hurting it or should I just live with it?  On a side note, can anybody identify the movement?  Any help would be appreciated, thank you.
David
Wait a minute- you won the watch in the first picture only to have the listing updated stating the watch had been re-lumed and a new picture posted?
Yeah, I wouldn't accept that- too shady.  The luminous paint in the second image is too bright and doesn't look proper.  It might be possible to remove it without damaging the dial but that's  not guaranteed.
The value of the piece has taken a hit too since the original luminous paint on the dial is gone- even if it's under the new paint, there's no way to remove just the new paint and recover the old paint.  The old paint is probably radium based which is another reason to avoid  messing with the dial.
Lastly, the regulator pushed way off to the side is an ominous sign.
same here, are you sure it is the same watch that you won or has the seller others on sale? If it is the same, I would stay away, maybe other things are changed too like the movement.
I am sure it is against the rules of Ebay to alter photos after a lot is sold
It is the same watch. He edited the description and added the two photos mentioning how his wife brought the wrong watch to his watchmaker for new lume.  I didn't even realize how far over the regulator was.  He had it listed several weeks ago but took it off because he said he accidentally broke the balance staff while wearing it and mentioned how he would relist it on eBay after his watch maker repairs it. I messaged him a few times after he ended the first listing which is how I know about the broken staff.  There are no shock absorbers so I know that is a possibility of being true.  I'm almost positive the dial had no lume to begin with. Which is why I was asking about removing what was added, plus most the circles are different sizes.  I should have it in hand in about 5 hours so I will post different photos.  I will post the auction if that is allowed on the forum.  The photos and extra description were 24 hours prior to the listing ending.   I had already put in my first bid, didn't even think of looking again when I put in my second bid before the auction ended.
Yes, that looks like a landeron 48.
Don't worry unduly about the regulator, that could simply be a case of the watch requiring a service and having been adjusted to compensate.
The dial certainly doesn't look right with that lume and eBay is typically pretty good regarding alterations being made etc.
On receipt get pictures including the movement to ensure that you've got what is pictured and not a substitute, that can happen.
Also, communicate with the seller if you're unhappy first as there's a possibility he/she might be amenable to giving a partial refund which might still make it worth your while.
If you decide to keep it, I'd recommend having that dial professionally restored as it's beyond 'patina' and is a mess anyway.
On a side note, I could use a minute wheel jumper spring for a landeron I have from someone for service if you're so displeased you want to move it along, Lol :lol:
Edited by m1ks
The proper watch was sent.  Tomorrow I am going to see if I can try and use a matchstick or pegwood to knock off the new lume.  If not I might just keep it with it. I'm a person that doesn't really like to mess with things unless it's completely destroyed. On the upside the watch does function as it should and the last five hours has been keeping good time. I really should invest in a time graph machine.  Thank you for all of the replies.
David
I think so although I'm not 100% certain, the parts more closely resemble the 48 rather than the 148 and 248 and the non shock balance.
I'd be concerned at that regulator being right over by the stud though, can you get a slow motion video of the balance swinging to see the amplitude?
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
