Standard Electric Clock Co Restoration
Louis71
Hi all
I'm new to this forum and joined to further my watch restoration knowledge but I was recently asked to restore this clock so I thought I’d share it with you.
The clock was bought in New York by a friend of mine many years ago but as it ran on 110v  it never told the right time in the UK!! The neon ring, which I’m pretty sure was fitted at a later date, was also quite faint.
I started by stripping the clock down and removing the hands, face and movement as well as the neon and transformer. I found a new mains movement from cousins with euroshaft fittings and soon discovered that unfortunately there was no way I would be able to salvage the original hands. I have a friend who has a cnc machine so I had him cut me a new set out of 1mm brass.
I took the neon tube to a local specialist who tested it for me. The original transformer was a death trap on 240v apparently but fortunately the tube was in good shape and much brighter on a modern transformer.
I guess the purists out there might have tried to make the original movement work but for me I was really happy to bring this clock back to proper working order.
55 minutes ago, oldhippy said:
Nice work. When replacing hands on clocks, you need to have the weight of the  replacements as near to the original,  it can cause the movement to run erratically.
Thanks. Yes if I'd have wanted to keep the original movement I would have probably tried to salvage the hands or if I had to remake them I would have made sure the hands were the same weight. As I chose a heavy duty mains movement as a replacement that can handle huge hands I was pretty confident it would be fine.
I like the look of some mains powered clocks, but the old mains powered movements are usually death traps, replacing the movement was probably the best idea.
I did once read how to convert Smiths mains clocks to run on 12 V AC but being your clocks came from the USA the frequency difference would still stop it from working.
Nicely done.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
