Mainspring service
bricem13
Hi
Well what is the right way to service the mainspring ?
My past experience is removing it by hand, cleaning, grease on barrel wall and reinstall by hand again. In general i ended up with quite greasy hands any therefore i would like to improve my technique.
I also broke a few springs putting them back in, when putting in the end with the short "spring" (dunno how it is called).
Best regards
Envoyé de mon Mi A2 Lite en utilisant Tapatalk
That made no sense at all mate. For a mainspring you can remove by hand, and you are correct with the grease and light oiling. As for putting the mainspring back in the barrel, I generally put mine in by hand but I also have a number of mainspring winders, no matter how I put them in the barrel I always wear either finger cots or latex gloves. These stop your hands getting greasy but more importantly stop contamination of the mainspring from the oils in your skin.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
