Watch oils?
stevew
With so many watch oils available nowadays, with different ones for different parts of the workings, i have always wondered, what did they use years ago?. You see Clocks and Watches, still working sometimes, and obviously never had such advanced oils.
Obviously new improved lubricants come to be needed as finer( friction reduced) movements are manufactured. Hublot makes a multiple complication mechanical watch now, with fifty days power reserve, not neccessarily stronger MS, but less friction.
On the other hand, industry is to survive which some times neccessitate  abuse of the term NEW IMPROVED in adverts. Not to get into details of shroud bussiness practices.
Nano science is expected to come up with technologies to revolutionize lubricants as we know em today.
Many advancements have been made in the lubricating qualities of watch oils over the years, but perhaps the most important is how long they remain effective in use. That coupled with almost universally waterproof cases since the mid 20th century allowed a shift from having one's watch serviced every year or 18 months or so, to several or more years between servicing. When a watch is cleaned and reoiled every year then the old whale oil works very well (it really was from whales).
At the other end of the spectrum the senior lecturer at the school I studied told me when he was an apprentice the worst job that he had was making the grease for the tower clocks they looked after.
He had to go down to the butchers to collect all the offcuts and then they had to render the fat down to make grease for lubing the tower clocks. :startle:
Thank god now we can just buy a bottle of oil or grease.
Often quoted in Lee Child novels by Jack Reacher character is a substance called squalene.  A natural organic compound found in shark liver oil and olive oil, and was used by watchmakers to lubricate delicate mechanisms.
Also found on the sides of human noses !!   :hot:                   Not sure how long it would last before going rancid,  who nose :D!!!
I heard it said  that  whale  oil is still  unsurpassed  as a lubricant. At one time it was used in automatic  transmission  fluid..after they phased  it out here in the states there were for many years  a transmission  shop  on every  corner..
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
