Invicta Mod
DrG
Hi everyone.
Just wanted to share my watch for the day. Always wanted an Orange Doxa divers. So took it upon myself to do a mod that I could be proud of. After some research I decided to mod an Invicta 8926 with a NH35a movement. Just wanted to share the result with you guys.
Best,
Guido
IMG_8200.HEIC
22 hours ago, bjd1020 said:
Nice work!!!! What hand tool did you use??
Sent from my SM-G950U using Tapatalk
Thanks. To place the hands I use Rodico to set them in place and a manual hand setting tool to press them down. My and removal tools are also manual levers. Don’t use anything fancy for hand setting.
Thanks again!
  • Similar Content
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
