Smoothing versus cutting broaches: Do I need both?
rduckwor
You don't need a  smoothing broach for a hand. The smoothing broaches are for smoothing the in side of a bush. These ready to use bushes, the brass is so soft a cutting broach is all you need, if you look in side the bush after cutting it is left smooth so much it looks as if it has been burnished. That is all a smooth broach does, is burnish.
Always use good broaches, they will always keep there cutting edges. Cheap won't last long.
4 hours ago, rduckwor said:
I need to clean out the pipe on a second hand.  Smoothing versus cutting broaches?
Thanks,
RMD
Well, A cutting broach will, of course, make the hole larger and so if you wish the hand to still fit the pivot then smoothing broach is the way to go, depends on if you want to remove material or not ;) but be careful, even though they are smoothing broaches they may still bind in the hole as you turn and you run the risk of breaking the hand.
To be fair, I have found smoothing broaches useful for clearing out stubborn debris. I remember finding what I suspect was glue in a seconds hand pipe once and couldn't use acetone due to the hand being painted.
@rduckwor I have merged your "dual post" as it keeps the forum cleaner. Kindly be patient in waiting for other members to respond rather than opening new topics with the same subject matter - many people are on different time-zones - have jobs - or are simply spending time with family ;)
    correct me if i am wrong,  broches come in a set.   "roughing and smoothing".   vin
30 minutes ago, oldhippy said:
Normally in sets. The very large clock ones can be bought separately.   Interesting to read Marks view about glue in the pipe, not come across that before.
'nor me since! Some silly sod's attempt at securing a loose fitting hand. Granted about 15 odd years ago but silly stuff sticks in the mind :D
I have use a pin vice for chronograph second hands, you can do it, but only if you are talking a couple of hundredths of a mm.
Go slowly tighten only a little bit and test fit, easy to close it a bit more, real PITA if you go too far and have to open it out again with broach.
Bergeon of course sells a special tool to do this if you have a few hundred pound spare, else get by with a pin vice, just make sure it is a good quality one that closes evenly so all sides (or 4 spots evenly spaced) get closed in evenly.
Ugh.  I see broaches are not free either.
Something else to add into the "Want List".  Projects get set aside until I can get back to them and I am running out of room as I go broke!
But I'm having a fantastic time.  Thanks Mark!
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
