Broken click
Hello everybody,
So I was working on an Orient 46941 movement that belongs to my father, the hairspring was missing so I got a new one no problem i's all over the internet, I open the watch to service it and what do you know! The frickin click is broken (which broke my heart).
I looke on the internet  and found nothing at all, can anybody tell me what can I do or where can I get a replacement?
Ok how do I adapt a similar one? I tried one from a seiko but its tall
5 hours ago, jdm said:
There is no secret place to find Orient or any other brand parts, you may need to buy a dono mov.t o watch for parts, or adapt a similar one, etc.
Always post pictures when it's about a problem. And the correct section is "watch repair help". Not everyone reads all the forum.
Edited by jdm
Ok, I will try to get some good pictures and post them on the correct section.
And BTW I did ittoduce my self I (in a way).
BTW, we also have a section where it's considered polite to introduce oneself.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
