Replacing pallet arbor.
SparkyLB
This is my first endeavor after successfully disassembling, cleaning and lubricating, and putting back together a swiss movement.  No date or complications, just a center seconds hand.  I did not note the movement number underneath the balance.  It was a manual-wind orphaned movement.
On my second movement, an orphaned one picked up on eBay for practice, I made a beginner mistake and tightened the pallet bridge onto a pivot that was not in the jewel hole.  I've broken the top pivot.  I have about 6 other orphaned movements bought "for parts" and I've used a staking set to remove the damaged arbor, and took a pallet arbor from a different pallet with nearly the same dimensions.  I am having one devil of a time completing this task putting a replacement arbor into the now arbor-less pallet.
I've been at it for days, and taking a lot more time thinking than working.  So far I've isolated the "new" pallet arbor between two stakes in my staking set, with a flat, holed stake on bottom, and a rounded holed stake above.  If there's any part of a mechanical watch movement that's smaller than a pallet arbor, I don't know what it is!
I'm unsure on how to proceed.  I thought I might surround the bottom portion into the stake with Rodico to stabilize it as I attempt to place the pallet.  This is certainly a challenge in manual dexterity for me.
My plans are after the pallet is slid onto the new arbor, to tap a few times with the rounded stake in the hopes it peens the arbor just enough to fill to create a friction fit.  Short of that, I might use a slightly oversized flat holed stake from the top, and peen the pallet onto the arbor to the same effect.
Those who might have performed this task, is there a certain set of steps, or advice for a beginner such as myself?
Hi In todays world fitting an arbor to a pallet is rare usually a new pallet/fork is obtained via the make and calibre of the watch (the mark and number under the balance) and this is fitted as a replacement. Using a near enough staff and trying to fit that is only going to lead to problems regarding end shake and a non functioning watch. As mentioned by Watchtime some pictures of the movment front and back and the calibre and make of the watch are essential if you are requiring further assistance.
An hairspring stud pin, as used on some cheap mov't is way smaller.
Quote
The advice given above is the right one, get a complete fork replacement. I think you are skipping steps for a beginner, get first to the point where you can comfortably service a regular mov't without breaking or loosing anything, and enjoy the pleasure of having it run perfectly. You will have plenty of time and better skills for more demanding repairs.
Edited by jdm
Thank you all.  I will heed the advice and pick up a new, complete pallet fork.  It's somewhat reassuring to hear from those more experienced that I'm "skipping steps."  I was hoping for that kind of response rather than one that suggests that this is an easy task.
It's an FHF 96N calibre.
And yes, the hairspring stud pin escaped me.  That is far smaller!
Thank you all.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
