Replacing pallet arbor.
SparkyLB
This is my first endeavor after successfully disassembling, cleaning and lubricating, and putting back together a swiss movement.  No date or complications, just a center seconds hand.  I did not note the movement number underneath the balance.  It was a manual-wind orphaned movement.
On my second movement, an orphaned one picked up on eBay for practice, I made a beginner mistake and tightened the pallet bridge onto a pivot that was not in the jewel hole.  I've broken the top pivot.  I have about 6 other orphaned movements bought "for parts" and I've used a staking set to remove the damaged arbor, and took a pallet arbor from a different pallet with nearly the same dimensions.  I am having one devil of a time completing this task putting a replacement arbor into the now arbor-less pallet.
I've been at it for days, and taking a lot more time thinking than working.  So far I've isolated the "new" pallet arbor between two stakes in my staking set, with a flat, holed stake on bottom, and a rounded holed stake above.  If there's any part of a mechanical watch movement that's smaller than a pallet arbor, I don't know what it is!
I'm unsure on how to proceed.  I thought I might surround the bottom portion into the stake with Rodico to stabilize it as I attempt to place the pallet.  This is certainly a challenge in manual dexterity for me.
My plans are after the pallet is slid onto the new arbor, to tap a few times with the rounded stake in the hopes it peens the arbor just enough to fill to create a friction fit.  Short of that, I might use a slightly oversized flat holed stake from the top, and peen the pallet onto the arbor to the same effect.
Those who might have performed this task, is there a certain set of steps, or advice for a beginner such as myself?
Hi In todays world fitting an arbor to a pallet is rare usually a new pallet/fork is obtained via the make and calibre of the watch (the mark and number under the balance) and this is fitted as a replacement. Using a near enough staff and trying to fit that is only going to lead to problems regarding end shake and a non functioning watch. As mentioned by Watchtime some pictures of the movment front and back and the calibre and make of the watch are essential if you are requiring further assistance.
An hairspring stud pin, as used on some cheap mov't is way smaller.
Quote
The advice given above is the right one, get a complete fork replacement. I think you are skipping steps for a beginner, get first to the point where you can comfortably service a regular mov't without breaking or loosing anything, and enjoy the pleasure of having it run perfectly. You will have plenty of time and better skills for more demanding repairs.
Edited by jdm
Thank you all.  I will heed the advice and pick up a new, complete pallet fork.  It's somewhat reassuring to hear from those more experienced that I'm "skipping steps."  I was hoping for that kind of response rather than one that suggests that this is an easy task.
It's an FHF 96N calibre.
And yes, the hairspring stud pin escaped me.  That is far smaller!
Thank you all.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
