Timex Stem Removal
carlos123
I’ve been trying to remove the stem of my Timex moon phase watch for some time now without any success. I keep revisiting it, prodding and poking different bits and still can’t get the stem to let go. So instead of eventually breaking it, I was wondering if you experts could assist me in finding the right button, lever or clip?
I’ve looked around at different websites and it seems a bit of a Timex mine field and couldn’t find anything relating to this particular movement.
Thanks in advance,
Carl
is you look at the notch just where the stem inserts into the movement you will find a hairpin clip. Use a fine tip tweezers and lift it up. BE VERY CAREFUL becuase they like to go flying when you set them free!
Thanks JerseyMo, I will give that a try later, I did have a play with that clip but didn’t fully remove it - just in case...
Hopefully this will release the movement so I can get to the hands.
Cheers,
Carl
Managed to (eventually)get the stem out, however couldn’t get the movement out? Do you have take the glass out to remove the movement on this one? I noticed there were tags within the watch case, loosening these off didn’t help either [emoji2955]
Any help will be appreciated
Carl
On 9/26/2019 at 5:17 PM, carlos123 said:
Managed to (eventually)get the stem out, however couldn’t get the movement out? Do you have take the glass out to remove the movement on this one? I noticed there were tags within the watch case, loosening these off didn’t help either emoji2955.png
Carl
yes, the movement comes out the front.  Those tags are what hold the dial on to the movement.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
