Made Another Balance Staff
Cut another balance staff for an old British Pocket watch. Again used a piece of blued steel and cut 90% of the staff before breaking it off and flipping it around to finish the rolled table end and the lower pivot.31323cf47250603e868d329058c31523.jpg10bb56123418ec712defa3a6355a00dc.jpg9657b24a00da3c6e65bb444d2a2bbaf8.jpgc4dd55e98f96cc3f9f8e501334f7d332.jpgMeasuring the upper jewel hole with a pivot gauge.c90bf97bd859fa893c0cb11c3350e383.jpg547624baeb3a22a4e131ddb3e67dedc4.jpgbe261222e8f57e43eadf9ba7849ad673.jpg5d28b4ec69be49edf16c083d4284f95b.jpgd79a75831a39d38741a5d64709478f65.jpgf23c437ea8dc079130fa5751f5627314.jpgc78dbbe2fc01e4dd91a7a2374606a166.jpgb4214116ab4a4accb98df20e375a936d.jpg
  • Like 5
Nice job man, don't thing I could do that!
Your movies helped me a lot with my first 2 pocket watches, lucky they still worked before I take them apart and were compleet.
The Hebdomas ( still not started with that one ) like you have is missing his bezel, but if I see how you make this small parts, it must be possible for someone to make a bezel to???
Keep posting movies and pictures.
Your confidence grows with each success.:Bravo: You should advertise in watch magazines. With your skills, you could make a lot of money. There are very few that have the skill you have. Loads of watch repairers, very few watchmakers.  Nice clear photos too.
Thanks. Not sure how I would advertise? I actually love making balance staffs. The new DSZ-70 stereo microscope is great for examining my work and seeing any defects in the parts. Still cutting the part with x20 loupe however. Here is my messy deskf9e95bca19e3c47242cfe87c6406e713.jpg
I think this could be done out of brass with a three/four jaw chuck. The threading would be very tricky...unless you do snap on.
Nicely done.
I've only made 1 balance staff so far.
I've got a German aircraft clock that has a broken endcap jewel that also had both ends of the pivots worn flat. I've rounded them again and once I've received the new reamers for my jeweling tool and fitted the new endstone I will find out if I will be making my second balance staff as it may now have too much endshake.
Nicely done.
Good job. It’s all about the next adventure:)
1 hour ago, jdrichard said:
Lathes are easy to get on eBay. Then al you need is some tools and a steady hand.
Not that easy. You need to know a bit about them, other wise you could waste you're money and end up with a real turkey.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
