Made Another Balance Staff
Cut another balance staff for an old British Pocket watch. Again used a piece of blued steel and cut 90% of the staff before breaking it off and flipping it around to finish the rolled table end and the lower pivot.31323cf47250603e868d329058c31523.jpg10bb56123418ec712defa3a6355a00dc.jpg9657b24a00da3c6e65bb444d2a2bbaf8.jpgc4dd55e98f96cc3f9f8e501334f7d332.jpgMeasuring the upper jewel hole with a pivot gauge.c90bf97bd859fa893c0cb11c3350e383.jpg547624baeb3a22a4e131ddb3e67dedc4.jpgbe261222e8f57e43eadf9ba7849ad673.jpg5d28b4ec69be49edf16c083d4284f95b.jpgd79a75831a39d38741a5d64709478f65.jpgf23c437ea8dc079130fa5751f5627314.jpgc78dbbe2fc01e4dd91a7a2374606a166.jpgb4214116ab4a4accb98df20e375a936d.jpg
  • Like 5
Nice job man, don't thing I could do that!
Your movies helped me a lot with my first 2 pocket watches, lucky they still worked before I take them apart and were compleet.
The Hebdomas ( still not started with that one ) like you have is missing his bezel, but if I see how you make this small parts, it must be possible for someone to make a bezel to???
Keep posting movies and pictures.
Your confidence grows with each success.:Bravo: You should advertise in watch magazines. With your skills, you could make a lot of money. There are very few that have the skill you have. Loads of watch repairers, very few watchmakers.  Nice clear photos too.
Thanks. Not sure how I would advertise? I actually love making balance staffs. The new DSZ-70 stereo microscope is great for examining my work and seeing any defects in the parts. Still cutting the part with x20 loupe however. Here is my messy deskf9e95bca19e3c47242cfe87c6406e713.jpg
I think this could be done out of brass with a three/four jaw chuck. The threading would be very tricky...unless you do snap on.
Nicely done.
I've only made 1 balance staff so far.
I've got a German aircraft clock that has a broken endcap jewel that also had both ends of the pivots worn flat. I've rounded them again and once I've received the new reamers for my jeweling tool and fitted the new endstone I will find out if I will be making my second balance staff as it may now have too much endshake.
Nicely done.
Good job. It’s all about the next adventure:)
1 hour ago, jdrichard said:
Lathes are easy to get on eBay. Then al you need is some tools and a steady hand.
Not that easy. You need to know a bit about them, other wise you could waste you're money and end up with a real turkey.
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
