Made Another Balance Staff
Cut another balance staff for an old British Pocket watch. Again used a piece of blued steel and cut 90% of the staff before breaking it off and flipping it around to finish the rolled table end and the lower pivot.31323cf47250603e868d329058c31523.jpg10bb56123418ec712defa3a6355a00dc.jpg9657b24a00da3c6e65bb444d2a2bbaf8.jpgc4dd55e98f96cc3f9f8e501334f7d332.jpgMeasuring the upper jewel hole with a pivot gauge.c90bf97bd859fa893c0cb11c3350e383.jpg547624baeb3a22a4e131ddb3e67dedc4.jpgbe261222e8f57e43eadf9ba7849ad673.jpg5d28b4ec69be49edf16c083d4284f95b.jpgd79a75831a39d38741a5d64709478f65.jpgf23c437ea8dc079130fa5751f5627314.jpgc78dbbe2fc01e4dd91a7a2374606a166.jpgb4214116ab4a4accb98df20e375a936d.jpg
  • Like 5
Nice job man, don't thing I could do that!
Your movies helped me a lot with my first 2 pocket watches, lucky they still worked before I take them apart and were compleet.
The Hebdomas ( still not started with that one ) like you have is missing his bezel, but if I see how you make this small parts, it must be possible for someone to make a bezel to???
Keep posting movies and pictures.
Your confidence grows with each success.:Bravo: You should advertise in watch magazines. With your skills, you could make a lot of money. There are very few that have the skill you have. Loads of watch repairers, very few watchmakers.  Nice clear photos too.
Thanks. Not sure how I would advertise? I actually love making balance staffs. The new DSZ-70 stereo microscope is great for examining my work and seeing any defects in the parts. Still cutting the part with x20 loupe however. Here is my messy deskf9e95bca19e3c47242cfe87c6406e713.jpg
I think this could be done out of brass with a three/four jaw chuck. The threading would be very tricky...unless you do snap on.
Nicely done.
I've only made 1 balance staff so far.
I've got a German aircraft clock that has a broken endcap jewel that also had both ends of the pivots worn flat. I've rounded them again and once I've received the new reamers for my jeweling tool and fitted the new endstone I will find out if I will be making my second balance staff as it may now have too much endshake.
Nicely done.
Good job. It’s all about the next adventure:)
1 hour ago, jdrichard said:
Lathes are easy to get on eBay. Then al you need is some tools and a steady hand.
Not that easy. You need to know a bit about them, other wise you could waste you're money and end up with a real turkey.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
