Replacement domed acrylic crstal
Mlgboy
Hi All, looking for some help identifying the correct crystal type for a Tudor Advisor Alarm ref 7926 circa 1958. The watch has a retaining bezel over the crystal which is .5mm thick with an outer non stepped diameter of 29.4mm. Overall height is 3.7mm. Any help would be much appreciated.
Mark
On 9/15/2019 at 2:34 PM, jdm said:
These are called top glasses.
https://www.cousinsuk.com/product/domed-top-sternkreuz-st
They may need a slight sanding to fit. Download and check the catalog.
Found the correct inside diameter at 28.4 with an outside diameter of 29.7 and actually need 29.4. Any recommendations for reducing the size accurately while leaving a clean finish?
  • 6 months later...
Big thanks to JDM for the idea with the sanding block. Ended up 3D printing a holder to support the crystal in a drill press so i could reduce the outer diameter while it was rotating. Worked perfectly.
Edited by Mlgboy
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
