Broken Omega crown
Hi,
I wanted to repair and service an Omega Seamaster DeVille with a monobloc case. It has a two-piece stem so I pulled the crown.
Turns out I pulled the crown to bits :gym: That has never happened before LOL. The rubber snapped in the process.
Did I just ruin a perfectly fine original crown or can it be fixed?
It just gave way after many years. Replace the gasket if possible and put back together. Put it back together, maybe you will have to slightly press the outer rim of the washers with a staking tool before fitting so that it so slightly widened to make a good fit.
58 minutes ago, oldhippy said:
Just replace it with a new one.
43 minutes ago, Nucejoe said:
New crown.
I would but this is the original signed crown. These are expensive and the watch will be worth quite a bit less if I fit a generic crown.
Can't find a gasket though and a new original crown is 20 GBP. The reference number is the 14915 by the way.
Edited by Nutiborskoku
Added something later
Correct. Beside, a good principle in watchmaking is to repair where possible. Otherwise we could be just called parts swappers.
I didn,t think a new original crown would be this inexpensive.
Regards joe
  • 4 weeks later...
16 hours ago, swisschronic said:
I would say if you are really set on using that particular crown JB weild is worth its weight in watch crowns. Cold weld and a new gasket.
?!? Promising cold weld is the same as promising cold fusion - physics doesn't allow that. Read above to learn how it can be repaired without using gluse.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
