Citizen cryston, one piece
Ishima
Hi everyone I have been left with a citizen crystron.
It appears to be a one piece case indeed im certain theres no seem between the "case back" and case. Ive done many one piece watches however this being a bit rare and  a 600m water resistant watch (im thinking the glass will be near impossible to blow out withof air pressure) id really like to see if anyone had any experience or insights with these before I commit to trying to open it.
1 hour ago, oldhippy said:
Will that ring come off?
Being it a diver watch the rotating bezel is of course removable. Then use a Seiko S-14 or similar tool to remove the crystal.
Incidentally i couldn't find mine today, luckily Mrs jdm came to help!
Edited by jdm
2 hours ago, Ishima said:
Thanks for the help everyone but I think by whats being suggested it would be wisest for me to admit defeat here.
Why defeat, is not that much a difficult problem. Not even the tool is expensive. Of course, if you have no good reason to take it apart or aren't comfortable servicing the mov't or doing a restoration, then leave it alone and so be it.
Edited by jdm
Almost zero experience with removing and refitting bezels, it's a blindspot for me and ive always considered it too hair-raising, i'd rather let my companies' central workshop deal with the odd bezel issue, don't even have tools specific for bezel work, neither do I have an s-14 tool or simular, Im not exactly sure how inexpensive they are, but at the end of the day I'm only trying to carry out a battery change. (in theory, it might need more than that given its age) In short I just don't feel like there's a lot of profit in it for the cost and risk, better to focus on the other jobs i have and send this one up.
Actually, I'm kind of tempted to fix that blindspot now. got plenty of scrap watches to practice on, what's the minimum set of tools you'd suggest?
Edited by Ishima
There are probably more posting on diver's bezels than any other horology subject, anyway:
Removal: insert $2 Seiko type knife (any variety) and pry. Do not twist.
Fitting: watch and bezel face down on bench, both hands on back, push down with all your weight if needed. If doesn't snap in (very unlikely on old popular pieces) use a snap-back or crystal press.
S-14 or equivalent crystal pliers: check eBay. We aren't talking Bergeon robbery here.
If it’s anything like the newer citizen monocoque cases you pry off the rotating bezel and can see the crystal is pressed into a crystal holding ring which is then pressed into the case. Pry out the crystal and ring as a unit and you will see a lever to release the stem.
There's  gotta be another  way. This is a battery  powered  watch. Why would  citizen  make  it such a PITA to do such a routine  chore as battery  replacement? I just can't  envision  having to remove a bezel and crystal  to replace  a battery.
There is no other way. Note well, it is a 600m waterproof watch, these are normally built with as single piece cases, quartz or mechanical.
Edited by jdm
47 minutes ago, yankeedog said:
I guess.if you really need such a watch you must be willing to accept it's requirements.
Nobody needs a 600m diver's watch or for that matter not even a 200m one or a diver watch at all. Diving, even recreational, is done with wrist computers not watches, since some 25 years now. That being said I like to wear a diver's watch often, especially in water.
A single piece case construction is simply a sophistication and perceived robustness aspect, which is appealing to some buyers, like a tourbillon is to others, for a different style.
I just came back to report that this was indeed the case.
Our central workshop returned it to us undone , so I decided to remove the bezel and take a look, I was pretty overjoyed to see the notch and realised what I was looking at.
Im glad I shared your other suspicion early on regarding the stem lever, a lesser technician might have forced it and damaged it.
I now having it ticking and awaiting collection, thanks everyone.
Edited by Ishima
In the nicest possible way, you have no idea, my friend.:D
Theres so much out there designed to be difficult as possible, often on purpose.
Edited by Ishima
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
