Seiko 6309 - balance diagnosis
Khan
Hello
Thanks to helpful members here, I managed to dismantle the dial followed by servicing the movement. While final testing, I experience lack of swing in the balance wheel (as before service as well). I can't see any visual disalignments or damages. It behaves as if it was gummed up, even though power in pallet fork. Note that it runs freely when lying upside down on the bench. I'd be very thankful if someone can spot the issue.
Kind regards
Khan
Edited by Khan
Hi Melt
Yes, the train runs freely when pallet fork removed. The way I clean it is by bathing it in alcohol, lift the wheel and use a blower. I removed the diashock jewel but couldn't remove the jewel from its rear "cover", don't know the trick without it flies across the room.
Hi Nucejoe
It runs in a low beat - barely a quarter turn right/left. The impulse jewel looks intact to me. My local watchmaker couldn't see any faults by visual check. But he didn't removed the balance from movement for further analysis.
Hi khan,
To check for in beat position of the impulse jewel;
I set the piece on bench dial down (DD), let the balance come to rest, keep an eye on the fork whilst slightly turning the BW clock/anticlock direction. Impulse pin is in beat if a slight move of the wheel causes the fork to move. if not in beat, bring the impulse into beat position by moving the stud arm, mobile stud carrier on your movement is to facilitate bringing the impulse jewel into the right position to receive energy from the fork horn.
Another method is to check if ,( impulse jewel ,staff pivot, escape pivot fall on a streight line.
12 hours ago, Khan said:
...The way I clean it is by bathing it in alcohol, lift the wheel and use a blower...
Probably not directly related to the lack of amplitude you're experiencing, but if you are talking here about the balance wheel I recomend you not to use alcohol to clean it nor the pallet fork, as it might melt the shellac that glue the impulse jewel and the pallet stones in place.
Low amplitude can be caused by quite a few things as others have mentioned, also wear or faulty pivots, dirt or improper oiling. I hope you didn't oiled the pallet pivots/jewels, did you?
Edited by aac58
Balance pivot dose look worn short in the pic. @Khan what lubricant did you use on escape teeth? Suppliment power manually to compensate for MS.
If it runs fine dial up but doesn't dial down high probability the balance jewel on the dial side is dirty. You need to clean/oil that again.
Another issue you can check is if the hairspiring is out of flat. Look at the balance while installed on the movement.. it should be parallel with the balance spokes and the whole movement in general. If it is slightly tilted it will hit either the underside of the balance cock or the balance itself. This might only manifest itself in one position.
Good luck.
Anilv
  • Thanks 2
Hello all
Thanks to all the constructive advices -
I removed the pallet fork (no lubrication in the top/botton jewel, but moebius 9415 for pallet stones on the way) and installed the balance and it has the same slow swing rate. I re-cleaned the diashock jewels in isopropylalcohol (any better cleaning alternative)?. Now it´s swinging freely and much better! + - max 10 sec per day when laying down but loosing 1.5 minute per when upside down according to my clock tuner app. I think the hairspring is few degrees out of level, see attached image.
Edited by Khan
Did you remove jewels to clean? Peg the jewels?  How do you know if all dirt is removed?  I guess not.
If you will, just drop some naphta on top of both shock springs, and fork pivots.
you are likely to witness excellent amplitude, whcih means jewels are not clean enough. If the cause of poor amplitude is not found right there, we move onto checking other possible causes, like impulse not in beat, HS rubbing etc.
Regards joe.
Regards joe.
Hi Joe
You were right. The issue was decades old stuck oil in balance top/bottom jewels, on which I had to use pegwood a couple of times. Even the caps were stuck and not easy to remove. Now it's running and keeping time well!
Edited by Khan
:Bravo::Bravo:
Hi Joe
Thanks for letting me know, A drop of naphta, deisel fuel, avgas etc on jewels, temporarily frees the pivots which may be stuck in dried oil.  I recommend making a habbit of its use to anytime we suspect a lubricant issue.
I also recommend finding and fixing as many faults as we can, prior to final clean, But I am self though so not all my techniques may agree with scholastic teachings. Regards
Edited by Nucejoe
Oh
Glad you have it going. I had same problem cleaned the jewels without removal and did no difference. Had to remove them and clean properly, that worked. Just shows how sensitive the Balance is. I use alcohol too, well the 99% isapropyl, the other in Bottle is for de-stressing :sleep:
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
