Greetings all!
AMW
Hello and thanks for having, no wait...not knowing you invited me to join this forum. I have been a watch collector since I got my first watch in 1978 when I was 8 years old. It was a Mickey Mouse watch and I immediately fell in love with watches. I’ve owned hundreds of watches over the years, but I’ve traded, sold, lost, broke, all but what makes up my current collection. I mostly traded or sold many of my watches because as much as I’d like to be a centipede and be able to wear them all, I simply cannot. So now I’m down to a mildly responsible assortment, though there are still quite a few on my radar. Seiko is my favorite brand and I’m particularly fond of the late 60’s to the mid 80’s era of Seiko offerings. My collection isn’t full of Seiko watches, it’s well spread out. What I am most excited about is after all these years of looking up repair tips, I finally found a place that has the answers. I have one pressing question that led me to join, but I am also in the midst of repairing some others and I’m thrilled I have a place to get some help, and maybe offer some too. Anyway, greetings once again and I look forward to meeting as many of y’all as possible.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
