Watch tinkerer from the Netherlands
Nutiborskoku
Hi guys,
My name is Melvin. I'm 36 years old and I live in the Netherlands.
I've been tinkering with watches since 2014. I've finished the Timezone watch school course and currently, I'm trying to finish NoBSwatchmaker's courses.
Not really a collector although I do have a couple of watches. My favorite watch at the moment is a Speedmaster 145.022 from 1984.
I love Blues music, playing the guitar, baseball, and picking watches to pieces :)
9 hours ago, JBerry said:
Welcome to the forum! That's a beautiful Speedmaster
8 hours ago, Johnnie said:
Hi Melvin and welcome to the happy factory:thumbsu: and complement you on your Speedmaster.
3 hours ago, ITProDad said:
Welcome! You will enjoy this group. That is a nice Big-O
2 hours ago, Nucejoe said:
Hi Melvin, Welcome.
Thanks, guys :biggrin:
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
