  • 0
Cmmb8519
EB 8800 - lubrification of pallet fork pivots
Question
Hi all
Just finished service of a EB8800. This is the most basic version of it, with only one jewel in the hairspring pivots.
I would usually not lubrificate the pallet fork pivots (and did not on this one) given there is no friction, but since this one is metal on metal, should apply a bit of 9010 to the pivot ends of the pallet fork?
Sent from my SM-G975F using Tapatalk
Share this post
Link to post
2 answers to this question
  • 0
Yes you should. Metal against metal is not good and will create wear. Only the tiniest amount is needed other wise it will create drag. So small the amount you can hardly notice it. A good tip also is oil just a few teeth of the escape wheel and not the pallet pins, the rotation of the wheel and action of the pallets will distribute the oil.
Share this post
Link to post
  • 0
Plus you would be surprised,  ampltiude flies as you lube escape teeth.
Share this post
Link to post
Answer this question...
Loading...
