Making Springs—Click, Lever, etc.
Maybe I'm the only one that has problems on occasion when a click spring or lever spring takes flight never to be seen again. So, since I'm a hobbyist anyway I thought I may try making my own springs and was hoping some of you may have suggestions or other input. I guess the first question is what are springs made of? Can I buy the spring stock to bend my own springs?
Regards.
Regards.
I like your spirit, young man!! But, spring steel is a different animal. If you bend it beyond its design it will weaken greatly. Could break. But it is possible. And they are usually made of “spray no steel”. You might have better luck looking for the exact part you need. It’s amazing what people have that you might need, including on this forum.
As for having springs, especially those little kif buggers, fly into another dimension right before your eyes; well you’re not a watch maker until you fill that alternate universe at least 11/16ths FULL of horological fiddly bits. Welcome to the club, my friend.
Just a suggestion the next time you approach a potential flier, use rodico to tack it down to plate before you touch it. This usually catches about 25% of potential losses.
Good luck. If you do make your own I think w would all love to see it! Please?
I’ve done a bit of research and I keep seeing guitar string as a spring material. Just a guess but it looks like most click type springs are about .3-.4mm.
I have not looked at the OEM spring build process but I suspect the wire is heated then shaped otherwise such sharp bends looks to me like it would easily break the wire.
I know buying what I need is the easy answer but I like challenges so unless I find it is a big extended process then I’ll give it a go just for the experience.
Regards.
Regards.
Guitar strings!!??! Brilliant! Tempering after shaping might keep its shape. Can’t wait to see your progress. Keep us posted?
You may be interested in this previous thread: https://www.watchrepairtalk.com/topic/11979-spring-wire-for-a-click-spring-015mm
There has to be a market for these kind of springs! Anyone who works with watches and hasn't inadvertently launched a spring somewhere never to be found again at some time is fibbing! ^_^
After working on a movement where the date jumper spring was placed in just such a way that it could make a bid for freedom as soon as the retaining plate was gently loosened, I now always perform such an operation within a clear plastic bag!
Thanks for the link. I thought I searched well enough before posting, but I didn't. Since I'm located in the USA I use Esslinger and others here for parts and tools. Here is a 0.17mm with they have. This seems like about the size most click type springs require. Cheap enough to experiment with. Now, on to the process of making springs from wire...
https://www.esslinger.com/peerless-round-spring-steel-watch-and-clock-wire/
Regards.
There has to be a market for these kind of springs! Anyone who works with watches and hasn't inadvertently launched a spring somewhere never to be found again at some time is fibbing! [emoji5]
I tried building a small tent of plastic sheeting over my mat with holes for my hands and head. But I could only work in it for about 4 minutes before blacking out. So I decided to practice more, use rodico and patiently wait for like items to come up on flea bay to replace those that obtained freedom through deleterious means. Never thought to cover only the movement and my hands. Learn something every day! :-)
Hilarious :D    Good lungs though.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
